Need automatic barrel plating line
We are looking for a very good Automatic Zinc plating(Cr3 yellow passivation) line for a barrel set up for higher volume in Bangalore. Parts are made in Sheet metal.part wt is app. 4.4 grams plating thickness 8-16 microns, salt spray white rust -72 Hours,red rust-120 hours. plating to be done after Heat treatment. The Hardness after Heat treatment is 330-380HV30, So 8 hours of Hydrogen de embrittlement operation is must in plating.
Kannan Boopathi
part development - Bangalore
November 12, 2009
