Is surface conductivity grounds for rejection of anodizing
We have a customer who is testing our anodizing by using a conductivity meter. Their claim is that if there is conductivity, then the part has no anodizing. In this particular case the flat plate shows coverage, (no conductivity), on the flat surface but the edges, (lasered), show conductivity. Are they correct in their rejection of the parts as having no coating on the edge of the plates? Visually the parts look fine.
Fred Hoodsupplier - Eugene, OR
November 5, 2009
First of two simultaneous responses -- November 6, 2009
Fred
Anodize builds up perpendicular to the surface. If the laser cut edge has a minimal radius, and the anodize is thin, it is quite possible to have the condition you describe.
Refer to Table III in section 6.10.3 of MIL-A-8625F for guidance.
- Colorado Springs, Colorado
The laser cut edge has a remelt or slag area that is not anodizing. They are correct, but you can ask for an anodizeable part, which you are not getting.
James Watts- Navarre, Florida
November 6, 2009
