Demin water supply through the stainless steel pipe
In my plant we are using stainless steel pipe(Oxygen line) for temporary Demin water supply. My question is :
1) Do I have to do the Chemical cleaning for the stainless steel pipe line?
M Alif Yusri M Yusof
Chemical Engineer - Labuan, Malaysia
October 29, 2009
Please response as soon as possible
M Alif Yusri B M Yusof
Petrochemical Plant - Malaysia
October 31, 2009
In general, stainless steel used with DI water is 316 alloy that has been electropolished.
As long as your requirements are for water with < 1 Meg-Ohm-cm resistivity, either 304 or 316 alloy should work without special cleaning or treatment, unless disinfection is needed.
Lyle Kirman
November 4, 2009
