Thin Dense Hard Chrome Supplier Needed
u.s chrome
I am an engineer investigating a coating solution for a precision ground tooth rack (linear gear). Currently we are sourcing this from Japan and use Raydent as the coating. I will be domestically manufacturing these and would like to locate a vendor with a similar coating solution compared to Raydent. Application needs corrosion protection and lubricity. Looking for a local vendor in the midwest. Located in Minnesota.
Jake Stromberg
precision automation equipment - Vadnais Heights, MN, USA
October 28, 2009
u.s chrome
