Peeloff problem of electroless nickel from sulphamate nickel.
there is peel off problem of electroless nickel from sulphamate nickel.
before sulphamate we are doing cyanide copper.
Jagdish Mhadgut
emp - India
October 27, 2009
Hi, Jagdish. Do you go from the sulphamate nickel to the electroless nickel immediately, stopping only for very quick rinsing?
October 27, 2009
I used to have that problem when I was plating zinc die casting, do the following:
Change rinses
Carbon filtration for the nickel sulfamate, copper and adjust Ph to 4.
I had good result afterward.
Carlos Carrera
- Miami, Fl, USA
October 28, 2009
