Removing lacquer from newly plated brass
I had Iron and steel parts brass-plated with the intention of antiquing them. They finished them with some kind of lacquer or enamel, and my darkening solution doesn't work. How do I best remove this coating, keeping in mind that some of the pieces are too large for me to immerse them in anything?
Rob Emmet
hobbyist - Brooklyn
October 18, 2009
Rob, if you didn't specify any coating over the brass plating, then you take the items back to the platers and tell them to remove the unwanted and unordered coating at no cost to you.
Bill Reynolds
Bill Reynolds [deceased]
October 19, 2009
It might be wax also. Start out with lacquer thinner this on eBay or Amazon [affil links] Warning! highly flammable! and repeated clean cloths. Beware that it is flammable and can be explosive in a tight range of fuel air mixture. Long term breathing of the fumes is not good for the body.
Try ammonia this on eBay or Amazon [affil links] / acetone this on eBay or Amazon [affil links] Warning! highly Flammable! (1/3) mixture-bad smelling but very effective.Any paint stripper can be used too(solvent based!).Hope it helps and good luck!
- Zagreb,Croatia
October 23, 2009
