Slime/algae on surface of anodizing tank
     If you wish, before proceeding with this thread, we have a quick "Intro to Anodizing" available.
Q. Dear Mr. Probert,
I see it's an old thread, but I'm currently struggling with it.
We're testing an anodizing additive based on glycolic acid and I observed algae in water rinse tank after anodizing step. This helped me to find that we have bigger problem with algae, which are probably present in demineralised water station.
Since we used this additive, our sealing solutions are short-lived. Conductivity increases very fast and details are dull.
I think the line was contaminated with algae after the anodizing stage, because of additive.
I would be grateful for any advice on how to get rid of the problem.
PS. I hope you understand my English. ;)
RECOMMENDED ANODIZING & CHROMATING BOOKS
for Shops, Specifiers & Engineers
pinner
"The Surface Treatment & Finishing of Aluminium and Its Alloys" by Wernick, Pinner & Sheasby (1959 - 2001)
anodizing_runge2018
"The Metallurgy of Anodizing Aluminum" by Jude Mary Runge (2018)
surface_aluminum_king
"Surface Treatment and Finishing of Aluminum" by Robert King (1988)
anodic_ox_alum_henley1982
"Anodic Oxidation of Aluminum and Its Alloys" by V. F. Henley (1982)
alum_finish_reynolds
"Aluminum Finishes Process Manual" by Reynolds Aluminum (1973)
avail from eBay, AbeBooks or Amazon
Joanna Gawarecka
Lab technician - Smigiel, Poland
November 22, 2024
A. Hi Joanna. We'll advise Mr. Probert of your posting, and hopefully he'll reply.
Meanwhile if you search the site for "algae DI" you will read suggestions for addressing that source, and if you search the site for "algae dye" you can read about algae problems in anodizing.
Q. Dear Mr Mooney,
Thank you for your answer.
I have already read these topics and found this one ;)
However I used Acticide MV at all processing bath and rinses after anodizing stage. We also used potassium permanganate to disinfect the rinsing tank before sealing and the sealing tanks and it helped.
I need to find the root cause of the problem.
Joanna Gawarecka [returning]
November 27, 2024
Q. I am having problems with dark, slimy (maybe oily?) feeling substance on the top of my anodizing tank. I think it may be a type of fungus and believe it may be the cause of some very small pinhole sized voids in a black coating. Isn't there some type of biocide for acid? I hate to put anything in my tanks without knowing for sure. If anyone has any info on this, I would really appreciate you help.
Teri Andrews
anodizing plant owner - Albany, Oregon
October 15, 2009
? Are you using the glycolic acid and glycerin anodizing additive which feed algae?
robert probert
probertbanner
October 16, 2009
