Interference fit parts before anodizing
Has anyone had experience with anodizing 6061 parts that are assembled with an interference fit prior to anodizing? Will the resulting joint be reliably liquid tight?
Rod Takatamechanical designer - Plymouth, Minnesota USA
October 14, 2009
Hi, Rod. Parts "grow" substantially during the anodizing process. I am having a hard time picturing how you could put them together after anodizing if it was already an interference fit before anodizing.
October 15, 2009
I think that he is asking if he assembles the part and then anodizes it, will he have leakage at the joint.
If you are talking about the most liberal definition of interference fit, then I will say that there is a good possibility of leakage.
If he is talking about heating the female part and liquid nitrogen freezing the male part, then the leakage is significantly reduced. It then gets into the tolerances of both parts as far as things like roundness and run out.
Going into hot water and then cold water before the etch tank will reduce the visible effects as it will fill some of the "crack" with clean water rather than chemicals that will leach out later.
The joint must be tight. Otherwise the current will not enter but the acid will and the aluminum will corrode.
October 17, 2009
