How to remove a bad paint job on retro oven
Q. I have recently bought a 1960's reproduction oven that has been painted over with a dripping red paint. My question is how do I Remove this? I realize I will have to repaint with high heat paint but I have no idea how to remove the top layers of paint.
Cherry Dye
novice - Texas
October 1, 2009
A. Use a heat gun this on eBay or Amazon [affil links] on some high temperature paint?....;^)
Just kidding. You're probably looking at either a chemical stripper and some elbow grease or mechanical means such as sanding, grinding, etc. If it's old, be careful whatever you do as the old paint may have lead in it. I would suggest the proper mask and protective gear if you mechanically remove the paint.
If it's not too big, I would probably try some chemical stripper first. You can buy a small can and test it on a spot to see how well it's going to work. Then you can buy more if it does. If it's real big or has lots of recesses/nooks/hard-to-reach-spots-for-a-stripper, you might want to try finding someone who does sandblasting and see how much it would cost to go that route.
Christian M. Restifo
- Pittsburgh, Pennsylvania
October 12, 2009
