Hard chrome plating inside the cylinder
what all necessary care must be taken while hard chrome plating inside the cylinder (dia 50 mm and length 300 mm)
plating supervisor - Mumbai, India
September 30, 2009
A. It would take a small book to answer your question.
You will need an anode down the center of the bore that is about 25-30 mm in dia. It should be made of a lead alloy mat. It needs to be fixtured very well with no contact with the part which will be negative. You probably should wrap the anode with paper so that the anode does not touch the bore when loading the anode/part, and then remove the paper.
ID plating will generate trivalent chrome, so I would use a small porous pot to keep the solution fresh.
There is a lot more, and a consultant (qualified) would be a good idea. If not, read a couple of books on chrome before you buy the first item.
Q. We have been doing plating inside cylinder.(dia. 50 mm x plating length 100 mm, cylinder top end fully open dia. 50 mm bottom end is partially open for dia. 30 mm)
Plating shop Manager - Mumbai, Maharashtra, India
October 19, 2019
A. Dear Mr Nigade,
I suspect that your plating bath is contaminated with solid particles that tend to go and sit at the inner corner.
Please cleanse the bath and anodes thoroughly once over and try.
Khozem Vahaanwala
Saify Ind
Bengaluru, India
December 6, 2019
A. I'm not doing chrome plating. But from my observation, your parts have a deep hole. You may need additional anode inside the hole. Please be careful to not contact with your parts.
Also, please try to remove bubbles during plating. Racking position is important, so that bubbles can come out easily from the parts.
Asahi Aero Malaysia Sdn Bhd - Selangor, Malaysia
January 6, 2020
A. Hi.
To hard chrome inside the anode should be very close to the cathode area, 4-5 mm. To avoid gassing streaks from the plating procedure.
Anders Sundman
Consultant - Arvika,
Sweden
January 11, 2020
