  Thread 531/47
Removing gold coating from solid brass faucet
We have solid brass faucets and cabinet hardware in our home. I have already stripped the lacquer off of the cabinet hardware and treated them with ammonia this on eBay or Amazon [affil links] to antique them with fantastic results. After taking the lacquer off of the faucets, I have noticed that they are covered with a gold plating material over the brass. It removes easily with 00 steel wool this on eBay or Amazon [affil links] , but I am having loads of trouble getting it out of the detail work. The faucets are the brand Harden, which is no longer made. Any help would be appreciated.
Randy Burt
Hobbyist - Frisco, Texas, USA
publicly reply to Randy Burt
Blasting either with sand or glass beads will reach inside the smallest details. Sand leaves a dull finish but is more effective removing coatings. Glass is more gentle and leaves a satin finish. G. Marrufo-Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
September 28, 2009
publicly reply to Guillermo Marrufo
