Seeking hard chrome plating and finishing for hydraulic piston/rod made of ductile iron
One-piece piston/rod considered to be cast of ductile iron in order to save production cost. The part weight is about 10kg, dimensions: Ø225x35mm (piston) and Ø100x55mm (rod). Chrome required to provide proper finish for seals application and corrosion protection for exposed portion of the rod.
QTY=100 for initial order.
MFGR - Delta, British Columbia, Canada
September 18, 2009
