Best setup for solar cell inspection
I am trying to figure out the best environment suitable for visually inspecting thin film solar cells manually.
Can you please help me with my questions?
What recommendations you would make regarding the selection of suitable type of light source for inspecting a solar cell, can you also specify intensity too.
What would be the ideal setup of an inspection booth? Where should I suspend the light what is the best angle. What should be the distance of observation etc?
The solar cell is rectangle shaped and the size is 15 length and 8 inches wide.
Thank you very much
SS Switch Gears - Hyderabad AP India
September 17, 2009
