Stop off Lacquer for Nickel Plating
I look forward to sprayable and curable stop off lacquer to work in Watts bath up to 75 degree C. Properties needed wear resistance and nonconductive. Any suggestion?
Kaushik Magiawala
Plating shop employee - Ahmedabad, Gujarat India
September 4, 2009
There are all kinds that meet your described needs. Virtually all vendors that sell plating solutions will also sell the stop off.
You need to consider a couple of more criteria as in does the edge pull up when trimmed and how do you get the stuff off when you are thru.
I'm using masking glue from chen tse for two tone silver & gold plating and it's work good...
Made Permadi
jewerly company - Bali, Indonesia
November 3, 2009
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
