Cleaning Superplastically Formed Aluminium
I have a number of solar panel collector plates made in superplastically formed aluminium which show signs of surface corrosion - I now need to clean them up and protect them with suitable coating.
Anyone have any suggestions as to whatI can use to clean them up with - dipping is not possible (I do not have a tank big enough) so preferably a swabbing type treatment would be preferable?
Richard Dibling
- Royston, Herts, UK
I had to clean some aluminum panels that had corrosion and discoloration some years ago. I obtained a chemical wash from an aviation supply company that is used to clear the exterior of aircraft. It worked quite well.
David Williams
- Beaverton, Oregon
