Is it necessary to dehydrogenate after phosphating ?
Dear Sir,
We need to do Antiseizure phosphating + Dehydrogenation for one of the gear, which is with the hardness above 55 HRC.
What is the difference between manganese phosphating and antiseizure phosphating ?
Sir,is it possible ?, to avoid dehydrogenation, skip the acid pickling step before phosphating.
Thanks in advance.
Rajan Pawar
Rajan Pawar
Buyer - Pune, Maharashtra, India
August 30, 2009
Hi, Rajan. I have not heard the specific phrase "antiseizure phosphating", but manganese phosphating is intended for such purposes, so I believe they are the same thing. I have also not heard the word "dehydrogenate", but I assume it means what I would call "hydrogen de-embrittlement", which is done via baking for a few hours at about 450 - 500 °F.
It is possible to blast the oxide off the gears instead of pickling it off, and this will certainly reduce the pickup of hydrogen and the chance of a part breaking during processing. But manganese phosphating remains an acidic process with the potential for hydrogen embrittlement. If a failure would be critical, de-embrittlement is required.
August 31, 2009
Phosphating - in any flavor - iron, zinc, or manganese - is normally considered a hydrogen-embrittlement-free process; like mechanical plating, the deposit does not seal in the hydrogen. There have been instances of transient hydrogen embrittlement due to phosphating; all of the cases that I am familiar with resulted from the phosphated articles being subjected to stress before the hydrogen had a chance to escape (I'm talking about rush jobs where the parts were put into service less than 48 hours after phosphating!).
tom_rochester
Tom Rochester
CTO - Jackson, Michigan, USA
September 5, 2009
Sir,
The components we are talking about are going under grinding operation after phosphating. By your experience, the articles are going under stress within 48 hrs. needs hydrogen de-embrittlement.
Thanks for sharing your views and opinions.
prevention is better than cure.
Rajan
Rajan Pawar
September 12, 2009
