How to predict the life of Chrome Plating?
I had a sample handle chrome plated couple of months ago. It started rusting after a month. I'm an engineer by profession and I can't get this out of my head how to determine the life of chrome plating. There is lot information available regarding the salt spray tests but none of them really give you a relation with the real life.
Richard BhallaProduct Designer - NC
August 27, 2009
You are absolutely correct. Salt spray is a QC check and not a predictor because of the infinite amount of environments and uses. - Navarre, Florida Alas, this is the nature of corrosion testing. It's only good for process controls (e.g., testing to see if your process is behaving today as it did 6 weeks ago). It does not give you any idea as to actual performance in the wild. - Pittsburgh, Pennsylvania There are accelerated corrosion tests, but none of them will actually tell you how much will a specific item last under specific conditions. They are just ball park ideas. Guillermo MarrufoMonterrey, NL, Mexico Dear Richard, ![]() T.K. Mohan plating process supplier - Mumbai, India There is only one true way to tell how the parts will perform and that is to directly expose them to the elements. No matter how clever we get in the lab, we never really seem to capture the random nature of the weather. Where I work we have set up a weathering station whereby we monitor the weather conditions the parts are being exposed to and just leave the parts racked by the monitoring equipment. Aerospace - Yeovil, Somerset, UK Hard chrome depends on the thickness of the plating. Decorative chrome would depend on the thickness of the nickel and the types of nickel plating applied before the chrome plating is applied. The same thickness of a bright nickel plate will not have as much corrosion resistance as an equal thickness of duplex nickel. - St. Louis, Missouri, USA |
