Repolishing Diamond plate aluminum sheets in damaged area only?
I had 10 4x8 diamond plate sheets of polished aluminum.Water got between the sheets,causing electrolysis and damaged the finish.The damage is only in small to moderate areas.Is there a way to polish these stains back to original finish.
Thanks Stephen
STEPHEN JENNIS
HOBBYIST - PHILA, Pennsylvania
August 26, 2009
