What tarnishes the least? Sterling Silver or Silver Plated?
I make jewelry and notice that some of the cheap silver beads I buy never tarnish while the more expensive sterling silver I buy requires cleaning. Should I just stick to the silver plated?
Lynette Stark
hobbyist - Glendale, Arizona, US
August 27, 2009
Silver Anti-tarnish Strips
silver_tarnish_strips
A. The cheap ones are a cheap alloy while the sterling is nearly pure, thus the difference. If the cheap ones are good enough, I would go that route. If not, one of the jewelers might help with a post cleaning dip solution. I doubt if you want a clear coat paint on it.
Argentium Silver Earrings
argentium_silver
A. Try Argentium sterling silver -- according to producer it is very resistant to tarnish.Hope it helps and good luck!
A. Lynette,
The reason the sterling silver tarnishes faster is because of the copper content in the silver. Sterling is 92.5% silver with the balance being copper. A clean silver plating bath can plate high purity silver. Many platers today use an anti-tarnish dip after silver plate which also controls tarnishing. Good Luck!
Mark Baker
Fellow Plater - Syracuse, NY USA
