Antiquing rubs off faucets in soldered area
Antique Brass Faucets
antique_brass_faucet
Q. I am antiquing brass faucets that have soldered joints. The joints are buffed so no solder is outside the joint. After antiquing, areas near the joint sweat. It doesn't matter if I antique the faucet raw or plate it first. I have cyanide copper plated the faucets then nickel plated, then cyanide copper then antique them or end with brass plate then antique them. I have no adhesion problems but no matter how many plating stages nor thickness will seal the areas. I have tried many post-antique rinses, mainly high pH and sodium bicarb. What am I doing wrong?
David Fix
Job shop owner - Grand Junction, CO, USA
August 22, 2009
A. I know that you would not use leaded solder on a drinking water faucet, but something from the buffing area of the solder is leaving a fine smear of something. Try a dip in fluoboric acid after the caustic clean step and see if it helps. You can try it in the lab at very little cost.
Q. Need help with antiquing my faucet fixtures, my plating keeps rubbing off in the welded areas...why...any suggestions or comments?
David Fix
plating specialties - Grand Junction, CO, USA
A. Is this a repeat of your post of several days ago, or is this welding vs soldering?
Welding changes the metallurgy of the part in the heat affected zone. If you mean brazing, I would blame it on the flux that you are using.
