Will passivation effect the thermal emissivity of a polished SST surface?
Roger Hollister
- LA CA USA
August 17, 2009
Not at all.
Bill Reynolds
Bill Reynolds [deceased]
August 20, 2009
Passivated metal will have a metal oxide layer on it, which in the case of iron will have a lower thermal permissivity.
The limitations on heat transfer will depend on the thickness of the film, which is oftentimes small enough to be negligible.
Robert H Kinner
- Toledo, Ohio
August 19, 2009
