Thread 528/83
Shiny Brass is blinding My Horse and Myself
Hello Metal Experts, My name is Linn and I live in Woodland, Calif. I recently purchased a Western Saddle with a lot of Bling Bling ... It has Shiny Brass Concho's, probably about 25 to 30 including the screws. I have never seen a saddle that has Brass like this. Usually Silver is the metal of Western Saddles! I have been reading on line about how to darken this Shiny Brass. I bought Brass Darkener. I used paint thinner first to take of the plastic coating and then Q-tips ⇦ this on eBay or Amazon [affil links] on the Brass Darkener. NOTHING.......... I have watched videos about Liver of sulfur Gel. My problem is I can't take off the hardware on most of the saddle. Can I neutralize it with water/baking soda without wrecking the leather? Does anyone know about this? I just read about the Palmolive Dish soap thing and that sounds less invasive! Someone please help me! Linn
Linda GoodeNovice - Woodland, California
August 16, 2009
publicly reply to Linda Goode
C'mon now, Linda. Do you honestly expect us to believe that your horse has never heard of sunglasses?
A. You have to get the coating off before the brass darkening solution ⇦ this on eBay or Amazon [affil links] can work. Aircraft stripper should work, although it's really noxious stuff (methylene chloride). Alternately, you may be able to remove the coating by abrading it with a fine sanding disk on a Dremel ⇦ this on eBay or Amazon [affil links] .
August 17, 2009
publicly reply to Ted Mooney
A. As the problem is that these parts are too bright, scuff them with fine grit sandpaper.
Problem solved.
Blacksmith - Boone, North Carolina
September 6, 2009
publicly reply to Marc Banks
How can you talk about sunglasses for horses, Ted?
A horse that is constantly looking back to his saddle must be very ill. He must need a neck re-construction surgery. Also, it is advisable for Linda to look up while mounting. It's the safe way.
Monterrey, NL, Mexico
September 12, 2009
publicly reply to Guillermo Marrufo
September 14, 2009
WWEEELLLL! You could buy some blinders for the horse and Ray Bans for yourself although Serengeti's are a lot more fashionable, contemporary and expensive I might add! Or you could dress period and wear one of those old huge hoop dresses. That would cover the saddle.
Or, in all seriousness you can get some Birchwood Casey Brass Black
[Brass Black on
(gun shops sell it), steel wool and lacquer thinner
⇦ this on
[affil links] Warning! flammable!
(hardware store).
Wet the steel wool with lacquer thinner
⇦ this on
and scrub the brass fittings. Then apply the black with a cue tip or whatever. It will turn the fittings an old yucky tarnished color, for the lack of a more romantic description.
lacquer thinner
⇦ this on
will dry out the leather but you can retreat any affected areas with Neatsfoot oil (ranchers call it weasel piss here) or saddle soap. Tack shops sell both.
Oh and Ted don't sink your retirement savings into horsy glasses! I have a notion they won't sell that good. he he he he - Rod
Rod Henrickson
gunsmith - Edmonton, Alberta, Canada
publicly reply to Rod Henrickson
