Cleaning Procedure of Silver Plated Copper Braid
Our company uses silver plated copper braid for aerospace application, the braid has always contaminated with oil, tarnish and other. We would like to know the cleaning solution and procedure to clean and preserve its cleaness.
Raul Guerrero
project engineer - Cypress, California, USA
August 12, 2009
Since you provided very little information, we have to guess.
Consider multiple tanks with ultrasonics. solutions in each tank will vary, depending on what the material is that you are trying to remove. Use ultrasonics in the second rinse after each chemical tank.
