Hard-anodized coating grew a bump during dyeing
I hard-anodized 7075 and averything was fine until I dye the part when I took out of the dye tank got like little bump in the part?
Disraely Colonplating shop employee - Baltimore, Maryland, USA
August 12, 2009
OK, what is a "bump"? Did it wipe off? Are you sure it was not there after anodizing? Do you have a 5% nitric acid dip between the anodize and the dye? Are you racked on titanium? What is the dye tank made of -stainless steel or plastic? What is the dye tank heated with
- stainless steel?
Try to give us some more information.
