Do we need a separate Nickel strike?
Hello, we are wanting to plate some stainless steel tube with a nickel chloride solution at a pH of 5.9. This bath does have tin in it to corrode the nickel so as to give it a black look. We currently do not do a nickel strike on copper and we have had success plating flat stainless steel. The surface is 8 RA and the material is 316 grade 8 stainless steel. Do you think this is sufficient or should we use a strike?
Timothy VillalvaOp.Mgr. of a Manufactuer - Jacksonville, Florida, USA
August 10, 2009
Hi, Timothy. Whether plating the black nickel directly on stainless will prove sufficient is a matter of your application, and some testing. But it is not ideal by any means, and I think the rejects will cost you more than the nickel strike.
August 11, 2009
If you want your coating to be adherent, you will need use a nickel strike on stainless steel.
