Avoiding stains before clear coating brass
We have 20 gauge brass plates we run through a timesaver using 220 grit belt. What is the best way to handle parts so we will not have finger prints on them before we apply a clear urethane coating? What is the best clear coat to use for outdoors to protect the brass finish?
Tom Hendricksonmanufacturer - Clackamas, Oregon, USA
August 7, 2009
Try Everbrite [a finishing.com supporting advertiser] coating!Hope it helps and good luck!
Goran Budija- Zagreb;Croatia
August 19, 2009
August 22, 2009
You must provide your employees with cotton gloves at ALL stages of handling of the brass.
Install a small powder coating plant and use a "super durable" polyester or acrylic (if available) powder.
If you require more information you may contact me direct via following the link.
Birmingham, United Kingdom
Avoid handling the parts - if no-one handles them there will be no fingerprints. If that is not possible, use clean, cotton gloves. If you cannot keep the gloves clean, you need to either eliminate the contamination that affects the gloves, or clean the parts after handling them.
All surface finishing processes require cleanliness if they are to be successful.
