E coat is suffering "streaking" appearance
Hi I am Pauline and work on an sovent free E-coat line, I seen over the last few weeks a variation in the e-coat appearance, in the form of a streaking,at first I thought it was cream coat, but thats not case, I wondered if any one has come across this problem
Pauline BurleyE coat technician - England
August 7, 2009
contact the e-coat supplier - he will know the answer or at least point you in the right direction. Without seeing the process, plant and the problem, it is difficult to solve your problem.
Hello,
Run a check on the phosphated parts prior to E-Coat, see if the streaking is a carry over from the phosphate in the first place.
If not, I wonder if putting in some solvent will be detrimental to the bath in any way? This does happen when the bath runs low on Solvent.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
September 28, 2009
I've seen this before. In this instance it was the stamping compounds, the cleaner stage was not completely removing them. This was at an automotive assembly plant and one of the suppliers of stampings was using a compound that the cleaner stage would not adequately remove.
Ronald ZeemanCoil coating - Brampton Ontario, Canada
October 20, 2009
