What type of zinc oxide is used for galvanizing
May I know what type of zinc oxide ⇦ this on eBay or Amazon [affil links] used for galvanizing? and chemicals used to prepare the solution for this process. what are the types of galvanizing process? can you list the chemicals used for galvanizing?
Eric Ansongstudent - Accra, Ghana
August 7, 2009
Hi, Eric! This is not a criticism, just an observation, but you spelled galvanizing wrong 4 times (we corrected it). Although books may be hard to come by in your area, if at all possible you should try to find a book that covers the galvanizing process. Authors spend months or years organizing the information in a fashion designed so that you will learn fast from it. Good luck.
August 7, 2009
