Nickel Electroforming - ductilizers
August 3, 2009
Dear all,
We've been successfully producing nickel shells but they've always shown higher hardness than some samples we got from competition - ours around 260 Hv and competitor's 180 Hv.
Since a few weeks I've been noticing what we think might be an increase in the stress of the deposit (some planar test specimens get deformed on the periphery getting a bit ovalized - tensile stress?). This came together with an increase in the porosity and porous build-up of the backside.
The bath was properly filtrated and we removed metal contamination by plating a corrugated sheet at low current 0,2 A/dm2. No porosity or porous build-up happens now but the slight ovalizing still comes around.
I guess the reason for the higher hardness and ovalization is in fact the internal stresses. Do you know of a ductilizer I can safely use? Can 2-butyne-diol aid on this as it is a leveling agent?
Thanks for replying.
Best regards,
Paulo Vilaça
plating shop employee - Portugal
Sounds like something you can control by adjusting process parameters. Butyne diol, as you said, is a leveling agent, not a stress reducer.
Guillermo Marrufo
Monterrey, NL, Mexico
August 8, 2009
Paulo, what nickel bath are you using? If you want a sensible answer to your problem, we need to know what you are doing and what you are using! Sudden increases in stress can be caused by many things, including a contaminated bath, the wrong bath etc etc
You really need to be doing stress testing.I would buy a good book on electroforming with nickel and consult INCO's web site for the ideal parameters to get a softer material.
Remember GIGO ? if you provide zero information about what you are doing, no one can provide a specific suggestion.
