Scratches on fork pipe surface
August 2, 2009
My problem is scratches on the surface of product.Product name is Front fork Pipe, used in motor cycle front shocks.
Length of Pipe is = 530 mm
Outside Diameter of Pipe is = 25.40
Inside Diameter of the pipe is = 16.80 mm
HRB of the pipe is = 20~23
Surface Roughness Required is = 0.6 Rz max
Your help & Guidance required in this regard.
NADEEM UL HAQ
Production Manager - KARACHI, PAKISTAN
Dear Nadeem Ul Haq,
Your question is not fulfilled. Kindly convey in what process is the pipe made to achieve 0.60 Rz max. For example by polishing,grinding or any. Specify what kind of tool you use during manufacturing.
It will be more helpful to guide in your subject regards.
M.Arunachalam
India
Arunachalam.M
- Coimbatore, Tamil Nadu, India
August 6, 2009
#1 I'd check to find out where and how the scratches are occurring and try to correct the problem before it occurs. If it is an on going problem the #2 I'd take steps to protect the part such as masking or padding area prior to assembly. #3 Only as a last resort would I consider buffing out the scratches with a non-woven wheel.
tony kenton
AF Kenton
August 6, 2009
