What kind of coating increases OD and is abrasion resistant
increases O.D. and is highly resistant to abrasion?
thanks for your time.
student - Fiskeville, RI, U.S.A.
July 16, 2009
Hi, Craig. Please try to describe your situation rather than posting in abstract terms. Virtually any plating will increase the OD. Nickel plating or hard chrome plating are probably the most common procedures for building up worn ODs.
July 17, 2009
I have a piston and cylinder with excess play.
I am looking to increase the o.d. of the piston by .004" or
.005".
the coating must be wear resistant.
I am currently fabricating shims of polycarbonate and fastening them with Loctite 380 glue and 770 primer, which is working but is time consuming.
- Rhode Island
July 29, 2009
I would use Electroless nickel and plate only the piston. A good plater can come fairly close to the required dimension and you can buff a tiny bit of it off if it is minorly too big. Otherwise, it is a grind operation. I would not use chrome at anything less than 0.003 per side and it will require grinding.
James Watts- Navarre, Florida
July 30, 2009
