Nodular buildup at edges with chrome plating.
Q. Gentlemen,
We are an aerospace company that utilizes the services of the plating industry very frequently. We have always had trouble with nodular build up at the edges of parts when hard chroming was called for. Is there a particular type of edge prep (chamfer, radius, etc.) that we could employ to reduce or eliminate this issue?
Manufacturing Engineer - Kulpsville, Pennsylvania, USA
July 14, 2009
A. Generous radius and chamfer will help. Ultimately, you probably will have to look at shields or robbers to reduce the high current density areas. - Navarre, Florida July 16, 2009 July 17, 2009 A. Mr. Ramasayer, ![]() Asif Nurie [deceased] - New Delhi, India With deep regret we sadly advise that Asif passed away on Jan 24, 2016 A. Rick, Aerospace - Yeovil, Somerset, UK July 17, 2009 A. Edge area having high current density. So normally hard chrome will built up more faster on this area. Hard Chrome plater - - Selangor, Malaysia July 17, 2009 |
I thank all of you who have responded and now I'll go to my supplier and discuss these conclusions. A little knowledge can be dangerous.
July 28, 2009
Q. Current robbing when electroplating large and small exposed areas. Can anybody give me an idea of what is current robbing? How does it influence uniformity of thickness over a large substrate? How to minimize this effect?
Ravi E- Corvallis, Oregon, USA
April 23, 2013
A. Hi Ravi. Please tell us YOUR situation. Who told you something about robbing and why? "Robbing" can be a good and deliberate thing; it can be an accidental and bad thing as a result of poor racking. In either case it involves something stealing some of the current and thereby depriving another area of current: again, this is often a good thing. What is going on in your situation?
April 25, 2013
January 31, 2018
"What usually happens is that you call up greater than the final thickness you require and then grind back to size".
Brian Terry
Q. We are currently working on a piston which has an chamfer with radius on both ends. chrome plating is required till the starting point of chamfer. We have done the plating like Mr. Brian Terry suggested above. We are facing problems with blending the radii of the chamfer and the chrome plating since sharp edges are forming after grinding it to required size. We are looking for an edge polishing method to blend the radius. Please suggest any solutions to edge polish the chrome to blend it to the convex radius of 1 mm.
- Hosur, Tamil Nadu, India
