Thread 525/52
Etching Textures in Shoe Sole Molds
Q. We are trying to machine shoe molds using CNC machinery and we end up a fine surface finish. I want to know a method of applying textures such as matte finish, rough finish etc on the mold cavity surface. Please note that the entire cavity is not textured but only parts of it are.
Etching has been suggested as well as sparking.
Vikrant KandimallaOwner, Promoter - Hyderabad, Andhra Pradesh, India
July 8, 2009
publicly reply to Vikrant Kandimalla
A. CNC machining will remove metal in a controlled way and this will give you a smooth finish. If you want to produce an uneven surface, as shown in the images, you can use spark erosion machining. This will give you an almost random metal removal process that will produce your required matte finishes
publicly reply to Trevor Crichton
A. The textures that you show in your pics are too deep for sparking (EDM). You need chemical etching also known as mold texturing.
August 2, 2009
publicly reply to Guillermo Marrufo
A. You would have to use etching paper to provide the textures you need. These molds are aluminum, right?
Rahul Chakravorty- India
August 19, 2009
publicly reply to Rahul Chakravorty
Q. Yea, they are aluminum. I am not able to get over this problem. Even if I cast the molds, I am not able to incorporate the finish I want.
Vikrant Kandimalla [returning]- Hyderabad, AP, India
October 9, 2009
October 9, 2009
A. Vikrant,
If you cast the shoe moulds, you can have any texture that you want. You need only to put the texture on the pattern that will be used to make the moulds to be cast in aluminium (or any other metal).
You can have an original pattern made of plaster, wax, timber, epoxy
- just about any solid material - and then it is used as a master to make a more durable pattern which in turn is used to cast the working die. Given that you are dealing with a low melting-point material like aluminium, you can make the casting moulds from plaster.
Bill Reynolds [deceased]
publicly reply to Bill Reynolds
Q. How to cast iron in the desired shape, as China is able to make shoe molds in iron or aluminium? How is that possible? Any metallurgist, who can help in this?
Ankit sharmaG.S DIE MAKERS - Delhi, INDIA
March 25, 2019
publicly reply to Ankit sharma
Hi Ankit. As you probably realize, people have been casting iron for 2500 years. So I know that your question is not simply how to pour castings in general, but how to do certain presumably difficult things that are required to meet your needs.
But readers who are already selling their technology for casting shoe molds from cast iron will surely not give away their trade secrets, and readers without shoe molding experience like myself do not understand what those issues are that you question implies. So I think you'll need to spend a bit of time explaining what those issues are other than simply pouring molten iron into a sand mold. Thanks!
March 2019
publicly reply to Ted Mooney
