Matte Finishing Hard Chromed Chill Rolls
u.s chrome
Q. Is there conversion table available for Matte Finish value Ra 0.5, 1, 1.5, 2.0, 2.5 of Hard Chrome Steel Roller to UK & US Grit size as well as Screen values 100, 150, 200, 300, ..., 1200 lines/inch?
We require making a Matte Finish Chill Roll which would be Hard Chromed. The customer gave us samples of Matte Finish PE Coated Paper. The samples were sent to the supplier measure & check its Matte finish value, which reads Ra 50 -- 69.
The supplier gave us Matte Roughness Values for Chill Roll ranging from Ra 0.5 - 1.0 -1.5 - 2.0 - 2.5 to choose or opt from this range. This is very wide range. The supplier/ chill roll maker is unable to suggest the required Ra value of Matte Finish of Chill Roll to match or correlate the reference sample.
Kindly advise
Best regards
Dharam
Dharam Rathore
Technical - Nairobi, Kenya
June 30, 2009
A. A piece of coated paper is not what your customer wants. You must discuss the subject with him and reach an agreement to use an acceptable surface as reference. He is buying chromed rolls. A blasted and chromed piece of steel plate of the same hardness would be an excellent portable sample.
Guillermo Marrufo
Monterrey, NL, Mexico
July 7, 2009
Matte finish on chrome plated rollers
"Hard Chromium plating"
by Robert K. Guffie
Hard Chromium plating by Robert K. Guffie
(rarely)
(rarely)
Q. Dear technologists,
We are using hard chrome plated rollers with N2 finish with polishing operation.
We need to make Matte finish to get slight roughness with respect to application point of view.
Kindly provide suggestions on Matte finish
CHANDRASRKARAN MAN
- Coimbatore, tamilnadu, India
October 31, 2015
u.s chrome
