Does Baking of Trivalent Passivates Produce Hexavalent Chromium?
We have done some work on baking trivalent passivates. (Many of you may have read our work on trivalent passivates, heard it at Sur/Fin 2009, or at least heard of it.) We tested five trivalent passivates. After passivating, we subjected them to one hour at 400 °F. We tested each surface for hexavalent chromium by the ISO 3613 Test Method 5.5 using ISO 3613 Test Solution C (diphenylcarbazide). Four of the five samples tested positive for hexavalent chromium. (We also tested a 'blank' - a sample with no passivate, which tested negative.) Are these results consistent with the results others have obtained or are they an anomaly?
tom_rochester
Tom Rochester
CTO - Jackson, Michigan, USA
June 23, 2009
! Well, this is an issue if I'm applying trivalent on bolting going to a REACH Nation that requires <.1% hexavalent chrome.
Ian MacMoy
Technical Authority - Houston,Texas
April 4, 2025
A. Indeed. Tom has long been concerned that the trivalent chromium conversion coating processes may not deliver as much of their vaunted freedom from hexavalent chromium as we think.
It has been 18 years since my seminal work on this issue. There are a number of ways to respond constructively to this query: political, technical, and pragmatic. Political: It is accepted by the automakers and the EU that once articles leave the production line free from hex chrome, they are REACH-compliant. (This is almost universally the case.) Technical: Hexavalent chromium is an extraordinarily effective corrosion inhibitor. Once trivalent passivates are in corrosive environments, they will almost always generate hexavalent chromium in small but effective amounts. Pragmatic: Don't look under the rock.
tom_rochester
Tom Rochester
Workshop in ASTM B08 in May. We will be testing this and seeing if ASTM B850, internal hydrogen embrittlement release bake out is a cause of the trivalent flip to hexavalent and what percentage flips. -Ian MacMoy
Ian MacMoy [returning]
API 20P chair over coatings and platings - Houston, TX
