Painting over camoflauge paint
What is the best way to paint over spray on camo enamel or oil base and can a guy use a farm implement paint
Jerry Wagnerfabricator - Beaver Dam, Wisconsin, USA
June 22, 2009
June 25, 2009
Hi Jerry,
I would like to help... I could visit you on site and carry out some evaluations tests using several different paints purchased from your local D-I-Y. These different paints will be applied to create some very small test squares. I can't give too much away, otherwise I will not be able to charge you a consultation fee. However, these "paint test squares" will allow me to evaluate each paints; drying properties, adhesion to sub-paint and identify any defects arising during/after top coat application to sub paint film. Regards Terry, Birmingham UK
Birmingham, United Kingdom
Please continue such arrangements in private rather than the public forum. Thanks!
