Can I re-plate brass-plated dresser pulls?
I have a mid-century modern dresser with brass-plated pulls that are tarnished. I've tried to polish them with no luck. The pulls are not magnetic, I scratched the inside of one and it looks like silver metal underneath. I can see silver metal through a worn area on the outside of one of the pulls. I have read with plated metals that re-plating does not give good results. If I send to be re-plated, will they look alright? What do you recommend? Thanks.
Virginia Stark
None - Hilliard, Ohio, USA
May 27, 2009
Hi, Virginia. They are probably zinc die castings. You'll probably find replacements cheaper than replating due to labor costs on onesy-twosy plating compared to the pull manufacturer plating thousands at a time.
But if they are worth the cost of replating to you, I feel they can be successfully replated.
June 19, 2009
thumbs up signThanks very much for the advice, I decided to try one more time polishing. Dunked them in some boiling water first and lo and behold, a varnish coating popped off. Then with a ton of brasso and a lot of elbow grease, I managed to finish with a pretty good-looking polish job. I applied a coat of lacquer, re-installed and they look good enough for me. But I must say I will never try that again, very hard work.
Virginia Stark
August 26, 2009
