What is a bleach test for anodized parts?
I have some 6061 Alum. parts anodized to MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA] Type III Class 2 dyed black. The end customer has rejected the parts because it did not pass their anodize test. So what is this test? I was told that a drop of bleach ⇦ bleach/sodium hypochlorite in bulk on eBay or Amazon [affil links] was placed on the part and if it turns a different color it fails. It turned pink. I have never heard of this test or what the test is measuring or not measuring. If anyone could shine some light on this issue it would help greatly.
Mark HeatwoleMachine Shop - Plano, Texas
June 12, 2009
"Bleach" is sodium hypochlorite, alkaline, and attacks (1) aluminum (2) aluminum oxide and (3) hydrated aluminum oxide seal. It also turns black dye pink.This is no test, this is a strip.
June 18, 2009
Mark
There are some medical device manufacturers who specify a bleach test to qualify the seal. Their product will be exposed to a bleach solution as part of routine disinfecting.
Typically, commercial bleach is diluted 50% and applied to the anodize for 1-2 minutes without discoloring the surface. Very similar in nature to the ASTM B136 Test.
If your coating was not sealed, it would not pass this test.
- Colorado Springs, Colorado
If the bleach test was not listed or listed in a referred to spec, they do not have much of a leg to stand on for rejecting the parts. If you want to keep them as a customer, you should be able to negotiate a reasonable settlement for both sides.
James Watts- Navarre, Florida
June 20, 2009
Mark
I think that dying is not allowed for your customer, if this is the case, try to became a black color using electrolytic coloring but remember to use aluminum racks and not titanium racks.
- Blumenau SC Brazil
July 6, 2009
