Zirconium coating on aluminium
I would like to understand the technique of zirconium coating on aluminum for electrocoagulation of sewage.
RAM MOHAN
- Kannur, Kerala
June 10, 2009
June , 2009
Why, Ram? You'll always get much better answers here if you tell us whether you are a student doing a research project, or a potential buyer, or someone trying to manufacture the item yourself. Please tell us your situation. In the meanwhile, I think you will find that the zirconium is applied to the aluminum by cladding, as opposed to any method of coating. I believe you will find that sheets of zirconium are autoclaved to sheets of aluminum, then rolled down to thickness. I could be wrong, but if we don't hear to the contrary from someone, then I'm probably not :-)
