Electroplating copper on carbon nanotubes
My name is Vasudevan and I am currently pursuing my research to improve thermal conductivity of carbon nanotubes. There is a very large conductance drop at the interface between the nanotube array and the heater, so I had the idea of plating copper on the surface of the nanotube array. I tried using vinegar in bulk on eBay or Amazon [affil links] as the acid and a copper bar as an electrode, but copper did not bond to the carbon nanotube. Is there any other electrolyte and electrode combination which can work? Is copper sulphate this on eBay or Amazon [affil links] solution a possibility?Is there any other method which could work? There is a laser deposition technique, but it coats copper in the order of 10 microns. I would need close to 500 microns.
Your help would be greatly appreciated.
Vasudevan Raghavan
student - Cincinnati, OH, United States
June 2, 2009
I used copper sulphate as electrolyte and copper as anode. I got a thin wafer of copper deposit at 9V for 20 minutes.The deposit however did not bond too well to the CNT. Is there a way to speed up the reaction and also quote uniform layer of copper on the entire CNT surface? I was recommended copper sulphate solution and platinum anode, but platinum is very expensive. Could I use any other metal which is inert or can I stick with copper itself? The sample surface area is around 5 mm * 5 mm
Vasudevan Raghavan
- Cincinnati, Ohio, United States
June 4, 2009
I'm by no means an expert in CNTs, but sometimes wetting is a problem. Do you know whether the acid functionalizes the surface to improve wetting?
Wendi Sweet
- San Diego, California, USA
June 5, 2009
You may try some PVD technique - sputtering, cathodic arc etc. But it is difficult to get 500 microns. First have a thinner - few microns - adherent copper coating by PVD and then try electroplating.
H.R. Prabhakara - Consultant
Bangalore Plasmatek - Bangalore Karnataka India
June 7, 2009
June 10, 2009
Thank you for your responses.
Hyrdroxyl and carboxyl groups functionalizes the CNTs, but once they are functionalized, they lose their property.
I will try sputtering or laser deposition technique and then do electroplating. It may just help.
Vasudevan Raghavan
