How to prepare zinc bath for plating on the brass wire having D=0.250mm
please guide me how to prepare the bath for the zinc plating on the brass wire having the diameter of 0.250 mm and thickness required is 15 microns
Milan Patelplating shop employee - INDIA
May 25, 2009
Hi, Milan. Do you presently do any zinc plating in your shop? If so, are you using cyanide, alkaline non-cyanide, or acid? Do you intend to plate this reel-to-reel, or hanging in loose spools on a rack? If so, what size are the spools? Does it need chromate conversion coating? Do you presently have any plating lines for pretreatment of brass substrates?
From here, it sounds like you need to retain a plating consultant to come in and design a process for you, but flesh out your question and maybe we can help. Good luck.
May 25, 2009
