How to put #4 satin finish on aluminum pipe
I am looking a good way to blend a #4 satin finish on aluminum
Jeff Hennequin
shop foreman - Queenstown, Maryland
May 20, 2009
Dear sir
Use glass bead blasting.
Suresh Reddy
- Bangalore
May 26, 2009
How long are the tubes? What is the I.D.? How many parts /hr.? If they are longer than 12 inches you are probably better off with a non-woven wheel pass through system.
tony kenton
AF Kenton
May 26, 2009
