Electrical conductivity for soil by milliVolts
May 18, 2009
Hi,
we are trying to measure electrical conductivity for a soil but we did not have a electrical conductivity meter instead we used a pH meter that measure electrical voltage by mV (millivoltmeter), my question is how to convert this reading which was -4 mV in to MS-1,
I am grateful for your time to answer thanks.
Sydney/Australia
student - Sydney, NSW, Australia
Hi, Nawal. I don't believe that you can measure conductivity with a pH meter. Neutral water with just a little salt and low conductivity will read pH 7.0; neutral water with a lot of salt and high conductivity will read pH 7.0.
May 18, 2009
Lab grade pH meters have a setting that reads in m volts. After all, a pH meter is nothing but an extremely sensitive volt meter with some unusual probes. - Navarre, Florida May 19, 2009 May 20, 2009 Hi Nawal, ![]() Bill Reynolds [deceased] consultant metallurgist - Ballarat, Victoria, Australia We sadly relate the news that Bill passed away on Jan. 29, 2010. |
I think that for soil testing he is going to have to have probes of a very specific area. Also, for soil, he is going to have to supply a specific moisture content or the numbers mean absolutely nothing.
James Watts- Navarre, Florida
May 21, 2009
I had millivolts readings of hanna pH meter model 611 which surprisingly gave a similar figure with a conductivity meter reading in microsiemens but divided by a factor of 10.does this mean that millivolts have direct relation to conductivity?
simon mukonoconsumer - kenya
July 16, 2009
