Flash Hard Chrome Plating - Clarification
April 27, 2009
Dear Sir,
Am a process engineer (Machining), in one of our drawing I came across a note stating ID & face of a flange bore should be "Flash Hard Chrome Plated Polished Plating to a min case depth of 25 micron".
Kindly clarify:
1)What is Flash Hard Chrome Plating.
2)Whether the above stated plating can be done by normal chrome plating process or requires a special process?
Awaiting for your reply.
With Regards,
Yogeswaran Shanmugam
Process Engineer (Machining) - Chennai, Tamil Nadu & India
Hi, Yogeswaran. "Case depth" doesn't sound like appropriate terminology to describe chromium plating; and 25 microns hardly sounds like a "flash". Although it sounds like plating that would be done from a conventional hard chromium plating bath, frankly, it sounds to me like a spec written by someone who isn't very familiar with the process.
May 13, 2009
