Protective Coatings on Brass Plated Articles
I have been told by our plating chemical suppliers that the thermal stability of our brass plated articles is between 130 to 150 °C. In this temperature range, we cannot use certain clear lacquers that need higher baking temperatures. We are not in a position right now to use polyurethane lacquers which are used at lower than 130 °C baking temperatures.
Can anyone suggest lacquers that can be baked at lower temperatures without reducing the lasting qualities. The plated and lacquered articles must pass a salt spray test of 100 hours.
Aloke Mookerjee
- New Delhi, India
Aloke Mookerjee
My company has done some work on brass door hinges using using waterbase acrylic clear coats. Can be force dried at 140 °F for 10-20 minutes. If you need further information please contact me. Good luck. Gordon Vidt
Gordon L. Vidt
Industrial Coatings Enterprises - Heath,ohio
Gordon, could you please send me the source of the water-based acrylic. I would appreciate it.
Mandar Sunthankar
- Fort Collins, Colorado
Gordon Vidt Thank you for your response. I shall like to know more of your product.
Aloke Mookerjee
- New Delhi, India
