Low Temp. hydrogen embrittlement bake after Electroless Nickel
Q. I am seeking recommendations on post-plating baking operations for electroless nickel plating on case hardened steel. The plating is on an area that is not case hardened, but is up to 35 HRC. Typical baking temperatures for EN are 200 °C, but we would prefer not to heat this part above about 150 °C (300 °F).
Can we effectively bake out hydrogen at this temp., and what time is recommended for 0.0001 to 0.0003 in. of EN over Ni strike. Thanks.
Larry Hanke
Minneapolis, Minnesota
A. A long time ago, Enthone gave me a chart with time - temperature trade offs for hardening the EN. Since you are looking for hydrogen de embrittlement bake, and you EN is very thin, it would fall in the category of a reduced temp bake. It has been so long since I have done that, I honestly do not remember the numbers. It seems like we baked for 16 -24 hours at 300F. Getting it into the oven as quickly as possible after plate is the most critical factor. I did not think that 375 F would affect case hardening that much and it surely has minimal effect on RC35.
James Watts- Navarre, Florida
Hi Larry.
If you don't like to get a hardener on the part. You can bake the part in 148 °C for 24 hours.
Regard
Anders Sundman
Consultant - Arvika,
Sweden
