Court reporter asks what visual defect on coil coater sounds like "star val B"
When explaining different visual defects that can be seen on a coil paint line, words that sounded like star val B was used to explain one of these defects. I need the proper spelling. Thanks
Kathy Hollandcourt reporter taking testimony about it - Houston, Texas, USA
April 23, 2009
The closest thing to what you wrote that sounds even remotely similar and is a common term on a coil line is "starving".
Ronald ZeemanCoil Coating - Brampton, Ontario, Canada
May 10, 2009
Hi Kathy. Maybe "stardusting"?
