Need a pewter color finish for aluminum punch panels
I am using aluminum flashing to make tin punch panels for my cabinets. I am wanting to know if there is a way to make the aluminum have a gray/pewter color type finish. I really don't want the shiny finish.
Judy McBee
hobbyist - Richmond, Missouri USA
April 21, 2009
Rub 'n Buff Sampler
Ideally you should use real tin, Judy. But failing that, you might try a wax rub (this on eBay or Amazon [affil links] ) on the aluminum. Good luck.
April , 2009
