Ni elimination from waste water
April 6, 2009
I have waste water from chemical plant. The initial Ni concentration 1s 1-5 mg/l and I have to go down to 0.02 mg/l. What is the best way to do it? Is it possible to reach this limit? If not what is the lowest possible.
Yitzik
Yitzhak Marcus
ecology manager - Petah tiqva, Israel
Hi, Yitzhak. It's possible to get to zero with distillation or mixed-bed ion exchange. But whether it's practical to get to 0.02 mg/l may depend on the source of the nickel (electrolytic plating, electroless plating, nickel cyanide) and what else is in it. Can we have some particulars? Thanks.
The 0.02 mg/L limit will be extremely difficult to meet on a consistent basis.
When faced with a limit like this it is usually best to locate the source(s) where nickel enters the wastewater, and to treat them there so you have some other flows to dilute it. Ion selective IX is particularly effective in this type of application, with batch treatment of the regenerations.
Alternatively, you could investigate recycling the dilute nickel flows with an RO or DI and, again, batch treat concentrates separate from other flows.
Good Luck!
Lyle Kirman
April 16, 2009
That is a very tough limit.
If ammonia and other complexants are absent, add a few pounds of ferrous sulfate ⇦ on eBay or Amazon [affil link] /1000 gal water, then a few pounds of magnesium sulphate, then raise the pH to 10.5 - 11 with sodium hydroxide. Mg is a good coprecipitant for Ni.
If that doesn't work, try adding in some sulfur based precipitant, like sodium sulfide or DTC, after the ferrous add, and after adjusting the pH to about 9.
dave wichern
Dave Wichern
April 16, 2009
