Will a burnout kiln melt gold concentrate and/or precipitant
April 4, 2009
Hi,.I have as a new hobby melting gold. I just purchased a burnout kiln. I assume that this is good enough to melt gold. I have the appropriate crucibles. Can I melt gold concentrate with this burnout kiln. As reagents I have bonami, silica sand and sodium nitrate
⇦ this on
. Am I ok with these reagents and kiln.
Thank you so much for your co-operation in this matter.
hobbyist - Quebec, Canada
Ed. note: the inquirer changed her mind about this, and has requested that her inquiry be deleted. We did not want to delete Geoff's helpful response, so we deleted her name instead.
April 11, 2009
Wax melts at about 150 °C and final burnout temperature is usually about 675 °C. What does your kiln maker say?
Pure gold melts at 1063 C
I do not understand 'gold concentrate'
If you intend to make a business of this hobby, a very basic rule is
'Understand your materials'
I would suggest that you get a copy of
Practical Casting by Tim McCreigh ISBN 0-9615984-0-9 or something similar.
